Article 17 - Post Goods Issue
Article 17: How do I post a Goods Issue using transaction MIGO?
When should I use MIGO for Goods Issue?
Transaction MIGO is the universal transaction for posting goods issues when you need flexibility in choosing different reference documents and scenarios[9].
How to post Goods Issue using MIGO:
Step 1: Access MIGO Transaction
  1. Enter transaction code MIGO
  2. Select "A07 - Goods Issue" from the dropdown
  3. Choose the appropriate reference document type
Step 2: Select Reference Document Type
Document Type
When to Use
Example
R02 - Material Document
Issue against existing material document
Return processing
R08 - Order
Issue to production order
Manufacturing consumption
R10 - Other
Issue without reference
Scrapping, sampling
R01 - Purchase Order
Issue against PO
Return to vendor
R09 - Reservation
Issue against reservation
Planned material withdrawal
Step 3: Enter Document Details
  • Document number (if applicable)
  • Material number or select from list
  • Quantity to be issued
  • Storage location from which to issue
  • Movement type (system usually determines automatically)
Step 4: Verify and Post
  1. Click "Check" button to validate entries
  2. Review all data for accuracy
  3. Click "Post" to complete the goods issue
  4. Note the confirmation message and material document number
What information do I need before starting?
  • Material code or description
  • Quantity to issue
  • Plant and storage location
  • Reference document (if applicable)
Reason for issue (cost center, order, etc.)
    • Article 18 - Post Goods Issue for Production Orders
      Article 18: How do I post Goods Issue for production orders? What is Goods Issue for production? Goods Issue for production orders is the process of issuing raw materials and components to manufacturing operations. This reduces inventory and charges ...
    • Article 19 - Post Goods Issue For Customer Deliveries
      Article 19: How do I post Goods Issue for customer deliveries? What is Goods Issue for deliveries? Goods Issue for customer deliveries is the final step in the sales process where you confirm that goods have been physically shipped to the ...
    • Article 16 - Goods Issue
      Article 16: What is Goods Issue (GI) in SAP MM? What is a Goods Issue? A Goods Issue (GI) is a fundamental inventory management transaction in SAP MM that reduces stock in a plant or storage location[1][2]. It's the physical and systematic process of ...
    • Article 20 - Movement Types in Goods Issue
      Article 20: What are movement types in Goods Issue and when do I use them? What are movement types? Movement types are three-digit codes that tell SAP the specific reason and method for the goods issue. They determine how the system updates stock, ...
    • Article 22 - Goods Receipt
      Article 22: What is Goods Receipt (GR) in SAP MM? What is a Goods Receipt? A Goods Receipt (GR) is a transaction in SAP MM that confirms the physical arrival of materials into a plant or storage location, resulting in an increase in stock[1]. It's a ...
