Article 18 - Post Goods Issue for Production Orders
Article 18: How do I post Goods Issue for production orders?
What is Goods Issue for production?
Goods Issue for production orders is the process of issuing raw materials and components to manufacturing operations. This reduces inventory and charges material costs to the production order[3].
How to issue goods to production orders:
Method 1: Using Transaction MB1A
  1. Enter transaction MB1A
  2. Select movement type 261 (Goods Issue to Order)
  3. Enter plant and storage location
  4. Click "Order To" button
  5. Enter production order number
  6. Click "Adopt Details" - system pulls BOM components
  7. Verify quantities and adjust if needed
  8. Save to post the goods issue
Method 2: Using MIGO
  1. Enter transaction MIGO
  2. Select A07 - Goods Issue
  3. Choose R08 - Order as reference
  4. Enter production order number
  5. System displays required components
  6. Enter actual issued quantities
  7. Post the goods issue
What happens when I post goods issue to production?
Stock Impact:
  • Raw material stock decreases in the issuing storage location
  • WIP (Work-in-Process) increases if configured
  • Reserved stock is consumed if materials were reserved
Financial Impact:
  • Material costs are charged to the production order
  • Inventory value decreases by the issued amount
  • Cost of goods manufactured increases
How to reverse a goods issue to production:
If you need to cancel the goods issue:
  1. Use movement type 262 (Goods Issue Reversal)
  2. Enter the same quantities that were originally issued
  3. Reference the same production order
  4. Use the same batch numbers if applicable
  5. Post the reversal - this increases stock back
Important notes:
  • Goods issue can only be reversed before order confirmation
  • Always verify batch numbers match for reversal
  • Check cost impact on production order after posting
    • Article 17 - Post Goods Issue
      Article 17: How do I post a Goods Issue using transaction MIGO? When should I use MIGO for Goods Issue? Transaction MIGO is the universal transaction for posting goods issues when you need flexibility in choosing different reference documents and ...
    • Article 16 - Goods Issue
      Article 16: What is Goods Issue (GI) in SAP MM? What is a Goods Issue? A Goods Issue (GI) is a fundamental inventory management transaction in SAP MM that reduces stock in a plant or storage location[1][2]. It's the physical and systematic process of ...
    • Article 20 - Movement Types in Goods Issue
      Article 20: What are movement types in Goods Issue and when do I use them? What are movement types? Movement types are three-digit codes that tell SAP the specific reason and method for the goods issue. They determine how the system updates stock, ...
    • Article 19 - Post Goods Issue For Customer Deliveries
      Article 19: How do I post Goods Issue for customer deliveries? What is Goods Issue for deliveries? Goods Issue for customer deliveries is the final step in the sales process where you confirm that goods have been physically shipped to the ...
    • Article 25 - Post GR for PO
      Article 25: How do I post Goods Receipt for Production Orders? What is Goods Receipt for Production Orders? Goods Receipt for Production Orders is the process of receiving finished goods or semi-finished products from your manufacturing operations ...
