Article 25 - Post GR for PO
Article 25: How do I post Goods Receipt for Production Orders?
What is Goods Receipt for Production Orders?
Goods Receipt for Production Orders is the process of receiving finished goods or semi-finished products from your manufacturing operations into inventory[5].
When do I post GR for Production Orders?
  • Production completion: When manufacturing order is finished
  • Partial completion: When some quantity is completed and ready
  • Co-products receipt: When additional products are produced alongside main product
  • By-products receipt: When secondary materials are generated during production
How to post GR for Production Orders:
Using MIGO Transaction:
  1. Enter transaction MIGO
  2. Select A01 - Goods Receipt
  3. Choose R08 - Order as reference document type
  4. Enter Production Order number
  5. System displays materials to be received (finished goods, co-products)
  6. Enter actual quantities produced
  7. Verify destination storage location
  8. Post the goods receipt
Using Direct Production Order:
  1. Display Production Order (CO03)
  2. Go to Functions menu
  3. Select "Goods Receipt"
  4. System opens MIGO with production order details
What movement type is used?
Movement Type 101: Standard goods receipt for production[5]
  • Stock type: Unrestricted-use stock (normal case)
  • Stock type: Quality inspection (if quality management is active)[5]
  • Stock type: Blocked stock (if immediate quality check needed)
What information do I need?
Essential Data:
  • Production Order number
  • Actual quantity produced (may differ from planned)
  • Storage location for finished goods
  • Production date
Optional Data:
  • Batch number for the produced material[5]
  • Manufacturing data (shift, line, operator)
  • Quality certificates or test results
  • Shelf life information for perishable products
How to handle quality inspection requirements:
If material requires inspection:
  • Stock type automatically set to "Quality Inspection"[5][3]
  • Materials cannot be used until quality release
  • QM lot created automatically for inspection
  • Stock moves to unrestricted after successful inspection
What happens after posting Production GR?
Inventory Impact:
  • Finished goods stock increases
  • WIP (Work-in-Process) decreases if configured
  • Component stock remains consumed (already issued)
Production Order Impact:
  • Order status updates to show partial/complete delivery
  • Actual costs are calculated and allocated
  • Variances between planned and actual become visible
Cost Accounting:
  • Production costs transferred from order to finished goods
  • Standard cost variances calculated if using standard costing
  • Material consumption and labor costs finalized
    • Article 24 - GR for PO
      Article 24: How do I post Goods Receipt for Purchase Orders? When do I post GR against Purchase Orders? Posting Goods Receipt against Purchase Orders is the most common type of receipt, used when vendors deliver materials that you have formally ...
    • Article 23 - GR Using MIGO
      Article 23: How do I create a Goods Receipt using transaction MIGO? What is MIGO transaction? MIGO is the universal transaction for posting all types of goods receipts in SAP MM[3]. It provides a flexible interface for different receipt scenarios and ...
    • Article 31 - GR and Clearing Account
      Article 31 – How do I maintain the GR/IR clearing account (MR11)? The GR/IR clearing account temporarily holds the difference between goods received and invoices posted. Steps to clear mismatches: Run MR11. System lists POs where GR quantity ≠ IR ...
    • Article 17 - Post Goods Issue
      Article 17: How do I post a Goods Issue using transaction MIGO? When should I use MIGO for Goods Issue? Transaction MIGO is the universal transaction for posting goods issues when you need flexibility in choosing different reference documents and ...
    • Article 27 - Docs created during GR
      Article 27: What documents are created during Goods Receipt and how do I find them? What documents does Goods Receipt create? Every goods receipt transaction automatically creates two linked documents that provide complete documentation of the ...
