Article 37 - Quality Factors Beyond Price
Article 37: What qualitative factors should I consider beyond price?
Why look beyond the lowest price?
While the minimum value quotation serves as the baseline for comparison, experienced buyers often select vendors that may not be the cheapest but offer better overall value[3].
What qualitative factors matter?
Vendor Capability Assessment
Technical Competence:
  • Ability to meet specifications exactly as required
  • Manufacturing capacity to handle your volume
  • Quality certifications (ISO, industry-specific standards)
  • Technical support capabilities for complex products
Financial Stability:
  • Credit rating and financial health
  • Business continuity assurance
  • Investment in technology and infrastructure
  • Long-term viability as a business partner
Service and Support Factors
Customer Service Quality:
  • Responsiveness to inquiries and issues
  • Communication effectiveness and professionalism
  • Problem resolution track record
  • Account management and relationship building
Logistics and Delivery:
  • Geographic proximity for faster delivery
  • Distribution network and warehousing capability
  • Flexibility in delivery scheduling
  • Emergency response capability
Strategic Considerations
Partnership Potential:
  • Innovation capability and R&D investment
  • Willingness to collaborate on improvements
  • Scalability for future growth
  • Cultural fit with your organization
Risk Management:
  • Supply chain resilience and backup plans
  • Regulatory compliance record
  • Insurance coverage and liability protection
  • Disaster recovery capabilities
How to evaluate qualitative factors?
Scoring Method:
  1. Define evaluation criteria with weight percentages
  2. Score each vendor on qualitative factors (1-10 scale)
  3. Calculate weighted scores for each criterion
  4. Combine with price analysis for total evaluation
  5. Document the rationale for final selection
Example Evaluation Matrix:
Vendor
Price Score
Quality Score
Service Score
Total Score
Vendor A
85%
95%
90%
90%
Vendor B
100%
80%
75%
85%
Vendor C
90%
85%
95%
90%
When to choose higher-priced vendors?
Justified Scenarios:
  • Critical materials where quality is paramount
  • Tight delivery schedules requiring proven reliability
  • Complex specifications needing technical expertise
  • Long-term partnerships where relationship value exceeds cost difference
  • Risk mitigation when supply continuity is essential
Documentation Best Practices:
  • Record evaluation criteria before starting assessment
  • Score vendors consistently using same standards
  • Justify non-price selections with business rationale
  • Maintain audit trail for procurement compliance
Communicate decisions transparently to stakeholders
    • Article 14 - Compare Quotations
      Article 14: How do I request and compare quotations in SAP? When should I request quotations? Request quotations when you need to: Find new suppliers for materials without established sources Compare prices for high-value purchases Evaluate suppliers ...
    • Article 36 - Quotation Comparison
      Article 36: How do I compare quotations and select the best vendor? How does quotation comparison work? After vendors respond to your RFQ, SAP allows you to compare all quotations side-by-side using the collective number to pull related responses ...
    • Article 64 - Troubleshoot ASN
      Article 64: How do I troubleshoot common ASN processing errors in SAP? What are the most common ASN processing errors in SAP? ASN processing errors can occur at multiple points in the process, from initial receipt through final goods receipt. ...
    • Article 43 - Procurement Proposals and MRP
      Article 43: What procurement proposals does MRP generate and how do I process them? What procurement proposals can MRP create? When MRP identifies a material shortage, it automatically generates procurement proposals - recommendations for specific ...
    • Article 28 - Logistics Invoice Verification
      Article 28 – What is Logistics Invoice Verification (LIV) in SAP MM? What is LIV? Logistics Invoice Verification (LIV) is the final step of the procure-to-pay cycle. It records vendor invoices, checks them against the purchase order (PO) and goods ...
